neil271978
- Joined
- Jul 20, 2006
- 51
The motor is running at about half the speed it is capable of going. I had a mechanic test it out in the water the other day. He ran some tests on it. First he bent the propeller back into normal position, he said it was bent pretty bad. That made it go a little faster. Also he said that the prop shaft was bent which could be causing it to lose speed. Also a month ago I took the boat out and it cut off on me and wouldn't start back up. I took it to the mechanic and he replaced the water pump and impeller and cleaned the carb. He said that the motor overheated. But anyway he said the other day when he took it out that the head gasket probably needed to be replaced because of the overheating. He tested the 2 spark plugs and one was normal (at 90 degrees) but the other one was black at 110 degrees. However he didn't seem too sure of himself about replacing the head gasket. Can anyone tell me if he is right or if something else is causing the problem.
