Re: 86 Merc 150 XR2 powerhead removal
According to the temp gauge, and it is a new gauge, I run mid way between C and H at idle, when I take off it pegs the needle past H within 30 seconds after take off. Let off to idle and within a minute its back to the midway point. This is with 15 psi water pressure at idle and pegs the needle at 30+ above idle. I have a new water pump (complete, housing, base, gaskets, impeller) a new poppet valve kit was installed, new head gaskets and exhaust chamber gaskets. All water ports were checked while it was apart, all was clear of debris. I wanted to check the adapter plate gaskets but now I dont think I can get the power head off. Everything I try has only caused damage to the soft aluminum and it still wont budge. And to really make things worse now I have a small piece of screwdriver broke off between the block and adapter plate that I cant get out. I wish I could start this day over knowing what I do know I would have left it alone. I really need to get this thing apart but dont know what else to do. I think its MILLER time.
