I have a 60 Hp Merc that has been having some bogging issues. I have never worked on these motors before so it went to the local stealer to be worked on. After $1200 and 3 trips it still bogs severly. They told me the top cylinder has a little lower compression and that there are metal shavings in that cylinder and that the motor is junk. I know they replaced a switchbox (or two, don't know if there are 2) and the stator and supposedly cleaned the carbs. The motor will work ok for a while and then will bog real bad and barely putt around. What usually happens in this instance is a small peice of metal will be in the top spark plug gap. Cleaning up the plug will help for a while. There is no tach in this boat so I have no clue what kind of RPM it is pulling but even when it is running ok, it doesn't pull real well. I do know that the fuel filter housing doesn't fill all the way up with fuel, is this normal?
Can anyone point me to where I should start? Pull the head and see where this metal is coming from? Fuel supply issue? Rebuild powerhead? I have some experience with 2 stroke sleds and their carbs, are outboard carbs similar? Are there maybe a reed assembly on this motor that has taken a crap. Everything I have learned about Merc engines thus far is from reading from this site. Thanks for the help!
Bill
Bill
