Thanks for advice on other threads. I have an 86 Merc 150 xr2. I'll start from the beginning. Boat has ran great all year and recently started bogging and dieing while going to WOT, still started and idled great. Now it is hard starting and idles bad (spits and sputters). I found yesterday that if I hold choke in for about 10 seconds while slowly advancing throttle it takes off like it should. Temperatures seems to increase to 1/2-3/4 on gauge as well, even with good pee stream. I assume this is evident of a lean condition. The following has all been done in the last 6 months.
1.local boat shop (great mechanic) installed new stator and tuned up
2.carbs cleaned and rebuilt. even double checked floats after problem. all set at 1/16" per manual
3.fuel pump rebuilt.
4.water pump rebuilt last fall
5.new fuel hoses,inline filter, checked pickup tube and vent tube- both were clean
6.new primer bulb. i checked and only has flow 1 way
Today I found the enrichener valve is defective, but from what I have read this shouldn't affect running performance. I traced all fuel flow and fuel it getting to all carbs with good flow. Does anyone have any suggestions
Thanks
Thanks
