86 ns70a won't run
My mechanic check everything and nothing he can find is bad. Thinks it maybe the power pack. It ran great two weeks ago then this week took it to the lake and all it would do is fire up then spit and sputter.
Sea Rider
Firing/running at idle at neutral is way different that when OB runs at load when geared. If throttling more than at idle/neutral, say half throttle does OB accelerates even, misses ? Is fuel circuit, tank, lines, filters inmacculate clean, fuel pump in good shape ?
Happy Boating
pvanv
You need to diagnose, not guess. It could be something as simple as choke. The CD for that motor is available, but not many other parts are. See whether plugs are wet or dry... the usual checks.
TOHATSU GURU
You check the C D module by using the values found in the service manual. It's more likely that you have a fuel issue than a ignition system problem.
pvanv
Exactly what method did they use to clean the carbs? Are the plugs wet or dry? Wet = either flooded or no spark; dry = no gas.
