I recently aquired this Ranger BB with 150gt Johnson and orig Ranger Trail.
Motor was rebuilt but melted a piston dome; needs new piston & head plus general re-gasket and replacement of normal maintanance parts. Fortunatly, cylinder is undamaged.
Trailer will get repaint to match new boat colors at the far end of the project.
The boat has rot under both seat mounts. I will have to take cap off to repair properly and am ready for stringer transom repairs if needed; I ain't scared.
The hull is in great shape except for the known rot, but the gelcoat is worn down to where the metalflake is rough in some areas. I will be refinishing with paint rather than gelcoat since I am well versed with auto paint and cost will be more reasonable. I have found a source for metalflake to replicate the orig finish as close as possible, actually a bit finer and more sprayable but modern materials should give that Bass Boat Sparkle.
I am into this setup for $0 at this point, and am fine with the cost to restore an older boat bacause when I am through it will be as new, whereas buying used I could find the same problems down the road.
This will be my resto thread, pics will come if it ever stops raining in MO. I have to do some mechanical fixes on the deck boat and get it in the lake before I start the BB, so updates will be slow at 1st.
Any tips or suggestions are warmly welcomed; I'm glad I found these forums and have already spent hours reading this section in preperation.
