This E30ELCDM's wiring harness was shot so I replaced it. The motor will start and run but won't shut off, and I got shocked up around the block and when I touched the shift box. The original wires color were hard to ID. I have a wiring diagram for 85 30hp and a '79 35hp. The '86 30 has 4 posts on the terminal block yet the 85 diagram has more. The yellow wires seemed to be mixed up so from left to right I put 2 yellows, 2 Y/G, and two Y/b's. Red went in the far right. There was a grey wire from from the red boot left over and I put it on the red post since there weren't any posts left, and that's where the last one was. The Y/B wire went from the power pack, through a connector and spliced to a b/y in the red connector.
How can I correct this problem? Thanks.
