86 sea ray mercruiser ...prop no go
Status
Not open for further replies.
Tony 77
bought boat earlier this season. boat was running fine, about 35 mph, temp was fine, coolant level at full. Was running wide open for about 20 min, suudenly came to a stop. To the best of my knowledge I did not hit anything. motor runs fine, just won't go into gear. With motor off, engine in gear, prop will make ratchet sound while turning clockwise. will not turn counter clockwise. When boat stopped, coolant was empty, smelled burnt rubber smell. any help greatly appreciated
Trent
Re: 86 sea ray mercruiser ...prop no go
Look on the back side of the engine. Do you see "rubber dust"?? If so you have spun your coupler. Your going to have to remove engine and outdrive to fix.
Tony 77
thnaks no rubber dust. dealer said could of melted some baffles??? baffles me
flashback
Tony, I would check the coupler again, like trent said, what you discribe is a classic twisted coupler, once the coupler craps out your engine will overheat very quickly and the boat will stop moving. smells horrible .........good luck
Tony 77
blk-n-blu thanks for your help, thtas similar to what the dealer told me. just wanted as much outside advice as i could get, thanks again
Tony 77
hey guys, checked the back of the engine again, no dust....pulled plug, no rubber parts. Is there an easy way to see if its a spun hub on the prop
Is there an easy way to see if its a spun hub on the prop <br />
Scribe a Mark on the Prop,+ Hub........<br />Then Run it....<br /><br /><br />I Also think you need a Coupler............
wally jr
I just had a spun hub myself. my sistuation was it would go into gear at low rpms. once i raised rpms the moter would wind out and the boat would stop with no prop turn. your drive should still go into gear and the motor should rev with a spun hub to my knowledge..
Status
