Re: '86 Sportcraft Cuddy 18'9"..........Tilt Hose Routing
Theres a little port on the front of the outdrive under the engine that the lines are threaded in to. If you need to get to them look under the outdrive on the outside of the boat, theres 2 nuts and a plate that has 4 lines coming off of it. Just undo those nuts and the plate will come off and you can undo those lines that you are talking about.
