I Don't think I have any choice but to replace the wood in the transom. You can see in the first picture the bowing out. Thats a 4 foot level for a straight edge with the ends touching, but it's lacking over a 1/2" in the middle. It had a home built kicker motor bracket, seen on the left of the second picture, and when removed, you could run a screw driver into the wood inside the bolt holes. I'm planning on building up the transom and cutting down the splashwell and replacing with a casting deck. I've seen several boats on here with them removed, and some say the splashwell is structural. I'm not sure. Looking at pictures of other hulls of the Starcraft/Sylvan/Smokercraft line, I've spotted some differences in the construction, from different years, and manufacturers. The Starcrafts, for instance, always seem to have a contoured/shaped splashwell, where as the Sylvans seem to usually have a staright one (cheaper, no doubt) Also, I've seen differences in the bracing and brackets. While they all do the same things, some are just shaped and configured differently. How much of this is due to the eventuall/current owners, I don't know. I do know my transom wood is completely encased in aluminum. The only, and I mean only, wood exposed is a little 3/16"x1/2" corner, due to a poorly fitted corner bracket.
I'm not afraid to overbuild, but I'm not sure I need to. My plan is to rivet in the transom build-up. As can be seen in the pic, I have a long shaft motor, on the short transom. I bought it this way, and know the motor, therefore I'm keeping it, but doing away with the shop built jack plate. I'm thinking about using LineX, or similar, to repaint afterward. I know a lot of people do away with the board between the motor and transom. I'm thinking a couple coats on the splashwell and transom, and a couple on the motor mount face? Also, its got 18 screws filling 18 needless holes along the bottom.
I've never liked the idea of wood in a transom. My first fiberglass splinter was obtained helping my Grandpa replace a rotted transom. Kinda been sour to wood in transoms ever since. So, I've decided to try the Coosa board. I can't come up with a good reason not to. It's lighter, stronger, absorbs less then 2% moisture, never rots? I say sign me up! Besides expense, is there any reason I shouldn't?
Obviously, the wires need cleaned up! I wish I had got a better picture of that area. It has a wedge shaped 20 gallon tank under the splashwell. If time allows, I'm going to get a tank that will fit under the floor.
So, any suggestions?
