87 15hp Peeing Hot?
imported_Warren
I have an 87 15hp evinrude. I already replaced the Water Pump, thermostat, fuel pump etc. I'm not sure if its running hot but I need to know how much hotter the water coming out of the Tell-Tale is normal. It seems to be quite a bit warmer than the lake water. Its peeing like a champion but I really need to make sure its running perfect....Thanks in advance for any help you can give me.....Warren
bubbakat
Re: 87 15hp Peeing Hot?
yes it gonna be hottor. IT has passed thru w hot engine
The Marine Doctor
As long as you can hold your hand in the water comfortably it will be fine.<br /><br />TMD
