first the water stopped pumping all together then i did the following
i pulled the lu & checked the impeller and that looks good, i then blew air threw the pee to check for junk or clogs seems good. i did replce the water tube upper gromet cause that had seen better days.
i put it back together and nothing at idle, good stream at higher rpm
is that normal???????????
should their be a good stream at idle????????????
do i put in a water pump kit in for the heck of it and then hook up water to water tube to akle sure its not leaking at the upper gromet????????
ANY HELP WOULD BE AWSOME, WOULD LIKE TO GET GOIN FOR 4TH & GET SOME FISH!!!!!! THANKKKKSSSSSSSSSSSSSS
