diaric
- Joined
- Jul 8, 2006
- 532
my buddy was planning on bringing his boat for a big fishing trip in 2 weeks. decided better change the impellor before going, and check cause of lower leg lube leak. i got it all apart and removed the lower pump housing in case the seals were leaking. found the driveshaft bearing in pieces underneath. its a month to get a boat into the shop right now. whats the best way to fix this up? i've never tried to pull a driveshaft out and don't know how comfortable i would be at it or if the leg is pretty much toast from metal fillings or lack of lube.
