ok guys...thought i had everything worked out with my 87 evinrude 50 (new water pump assembly, new thermostat)...went to take the boat for a little spin today and it overheated again at the dock...when run at my house with the muffs on, no issue.....i noticed today that the pee stream is much weaker when the boat is in the water than when its hooked up to the muffs....i figure this is because the water is being forced in....but i also noticed that there is a signifacant amount of leakage from the seam between the lower unit and the midsection....is this normal or is it possible that i have an issue there....maybe something not lined up properly from when i reinstalled the lower unit?
this is my best guess because it seems like even thought this leaks, the pressure from the hose feeds enough water to the impeller to keep things cool, but when its in the water theres not enough pressure going up the midsection because of the leak? just a guess....other than that idea i'm kinda lost here
