87 Force 125 LF flywheel puller
robms6
Does anyone have a flywheel puller for a 87 force 125? From my research I am looking for the type of puller that bolts into 3 threaded holes on the top of the flywheel. It seems like all I can find is the single puller that bolts into the flywheel bolt. Also looking for a lift ring for it to I would love to use my engine hoist when I move the engine off the cart. Here is an example of what I think I am NOT LOOKING FOR http://www.amazon.com/Flywheel-Puller-Mariner-Force-Outboards/dp/B003N89SEK . I am in NJ
Thanks
Robert
bowtie2440
Re: 87 Force 125 LF flywheel puller
I'm glad this topic came up I was looking for one too . Thanks
DukeDelago
When I pulled the flywheel on my force 120 powerhead (which I believe is almost identical to yours) I used a harmonic balancer puller that I bought from Advance Auto parts for $15. It looks a lot like a chicken's foot, or a peace sign without the circle. You only need to use 3 of the four bolt spots, (at 0, 120, and 240 degrees; or 4, 8, and 12 o'clock). Ignore the one at 6 o'clock and it will work fine. The other three line up perfectly. I had to buy different puller bolts for it at the hardware store as well as washers which were both easy and cheap. Alltogether it didn't cost me $20 for the whole thing and worked like it was made specifically for the job. Also didn't need specialty stores. The only issue with this method vs the special tool they actually make for this is you will have to hold the flywheel from spinning as you tighten the puller. You can get past this with an impact gun but many will advise you not to. If you choose to go this route use the lowest setting only and take your time and use the gun for a quarter turn at a time at most between tapping on the center of the puller itself. Hope this helps!
Unforcefull Force
You're welcome, like Duke said, you can also purchase these at your local auto parts store or harbor freight.
All around 15-30 bucks, but you can spend as much as 200.00 for one! I wouldn't recommend that though!
-Mark
