87 Force 125 tilt/trim
TINCAN46
Working on an 87 Force 125 .No tilt/trim. There are no relys for the tilt motor under the cover. The dash switch looks like it carries the load as there are 3 large gauge wires to the switch. A green for down, blue for up and a common. Should this supply +12vdc or does it supply the ground to complete the circuit? I checked it with a meter with ignition switch on and no voltage in any terminals. Am I missing something?
jerryjerry05
What color is your motor? The white stopped in 86. the 87 was blue.
The 87 should have the relays under the hood, unless it was ordered without T@T. I never saw a 1987/125+ without T@T However some 85's came without it.
The older 1986 and past had the switch on the dash with #10 wires that went to the T@T. The 3 wires Red(power), Blue(up) Green(down).
The red was attached to the battery along with the black ground wire, both found in the battery box area..
