davescountry
- Joined
- Apr 4, 2008
- 20
Hello all - I am really needing some advice here.
I looked at a boat today with a 1987 Force 85 HP on it. The fellow who is selling it bought it new with the boat in 1987. It has been sitting since about 2001 and hasn't been started.
The boat itself looked pretty good. It has been kept inside. The guy selling it seemed like he took pretty good care of things. Although I did ask him if he had ever changed the water pump / impellor and he said 'no' he never had to. I have an old Johnson and have always changed mine every few years just out of general maintanance.
The guy selling it had drained it of gas, so that is probably a good thing. He put a new battery in today and I was able to test most of the electrical system and it all worked fine. I was able to turn over the motor and it cranked, so i can tell the head is not seized. I pulled the engine cowl and the engine looked surprisingly clean and the wiring appeared to be in good condition.
The guy did not offer to put any gas in it to see what it would do. He did not really say that I couldn't but he did not offer to let me either. I don't think he was hiding anything, I just think he does not want to put out much effort in getting rid of this.
So, I guess I have a few questions for everyone. The first being, what is everyone's opinion on the liklihood that this motor will run out OK with little to no problem.
Next, if it is likely that there will be problems, what would those likely be? I am thinking it will probably need a carb rebuild. I have no experience with Force motors, so I have no idea of what that might be like. I have rebuilt a few older model Johnson carbs,and although not fun, I can do it.
I don't even know if this motor has electronic ignition or points. I guess that might be another problem area.
I guess I am considering making this guy an offer, but not sure yet. I may ask him if I can bring a gallon of gas along with me and see if it will fire. I was also thinking about trying to check for cylinder compression and spark, although I don't know what the compression should check out at.
I am really looking for any and all input. Things to look for, things to test, what I might be getting in to, pretty much anything. Any opinion is valued.
