'87 Four Winns 215 Sundowner help needed!
Smart Boy
I just bought a 1987 Four Winns 215 Sundowner equipped with a Mercruiser 260 and an Alpha One outdrive. I have been going through the boat to test and check everything before taking it out with my family. Overall it is in great shape, but I do have a couple questions for you "experienced" Four Winns owners.
1. There is a hole on the Starboard side front of the boat that looks like it is for a bilge pump. I have searched the boat and cannot find anyway to access this from the inside nor can I find a second bilge pump that may be hooked to it. Does anyone know what this is used for and if it is indeed for a second bilge pump, where is the pump located.
2. Where can I get parts for this boat? I need a trim gauge, I already tested it and it is the gauge. I also need a handle for the hatch in the cuddy cabin.
3. Is there any good way to test the impellar in the outdrive? I read that with the ears on you do not get an accurate flow. Another thread mentioned submerging the drive in a trough of water and starting the engine with the outdrive to engine hose off. If this method will work, how much water should it pump? How hard is the impellar to change? I am a mechanic, but I have noooooo experience with boats or outdrives. The previous owner had the outdrive rebuilt last year (he had the receipt) and only took the boat out once since then. I just want to make sure everything is in good working order.
4. The exhaust "flapper" on the starboard side is rattling alot. The previous owner had a receipt where he took it in for this problem and the mechanic said it would be O.K. Should this be a concern or not?
5. Do you know of any other common problems I may want to look for before taking this boat out.
Thanks in advance for all your help.
Silvertip
Re: '87 Four Winns 215 Sundowner help needed!
I can't help you with the "outlet" you mention but if you intend to do any work on the engine or outdrive yourself, as a mechanic you should know the value of a service manual. Buy one from Mercury (Mercury Parts Express). You will need your model and serial number. While the manuals are a bit pricey, consider the damage one screw up will cost you.
serski
Smart Boy, is this your 1st Four Winns? After reading your #1. question, I imeediatley thought of your cooler drain? On the passenger side you more that likely have a dash cooler, the drain hole on the side is the self draining port hole for the cooler. You should be able to fit "plenty" of beverages plus ice in this baby! I absolultey love this four winns feature!
Coors
#1 anchor locker
#3 replace it, takes 15 minutes
#4 replace
craig stevens
my boat has the same drain , its a standard fitting in a lot of four winns for sinks etc and for other problems watch your electrical carefully four winns does no use marine wire or connectors
Fourwinnsme
I have a 1987 215 Sundowner with the Inner liner and the fish package.
The cooler drain is on the port side and the starboard side going from bow to stern has the anchor locker drain, Fishwell drain, and the bilge pump drain.
yes hi i have a 210 sundowner and the hole your talking about in the front is a drain hole for the anchor hatch
