87 Johnson J225 TXCUB, NO SPARK
capt-m
I have a 87 Johnson J225TXCUB, The Boat has been sitting for a long time, got it running after Rebuilding the carbs and misc other things started it and it ran rough because the Gas was over a year old, I thought was the issue. I Tried to start it and after sitting for a week NO spark at all. I have power on the Purple wire to the Rectifier/Regulator but no power coming out of it? I was told that the Rectifier would probably be my problem??????
SparkieBoat
Re: 87 Johnson J225 TXCUB, NO SPARK
you need to get the dva adapter in my sig below and download the free troubleshooting guide
boobie
Find the black/yellow wire coming out of the power pack and disconnect it. If you have spark then you've got a boat wiring prob. If not, mtr prob. The reg/rect has nothing to do with the ign system.
capt-m
I have 2 CDI power packs neither side has Spark. I have disconnected the the Kill wire and plugged it in, no difference. and Why Spartk last week and now nothing
SparkieBoat
disconnect the wire harness big red plug and then jump solenoid..see if you have spark then..if not, do post number 2
dehydrated
have you checked the shift interuptor switch make sure wires are on has voltage coming in and out just a thought but my wire came off one side no spark could be that simple
capt-m
I haven't looked there yet but I will ASAP I'll let you know what I find.
