I have a 1987 Johnson outboard that is getting stuck when giving it 3/4's to full throttle. When I try to back off the throttle it keeps accelerating even in Neutral until I turn off the ignition to kill the engine. Luckily this has only happened running on muffs in the driveway but now I'm afraid to take it out.
Also this started happening after I was adjusting all of the idle and linkage adjustments to resolve a loss of reverse problem I had encountered last time I had it out. I thought I had it just right when it was shifting properly again in forward and reverse without grinding or bogging out in a test tank, but now this.
I just want to know what to focus on so I don't create the prior problem (no reverse) again by messing with the wrong adjustment.
Any help would be greatly appreciated.
Thanks, Jesse
Thanks, Jesse
