Re: 87' mariner 150
Thanks for the info guys. Here is some of the results on the troubleshooting I done. Orignally there was no fire on cylinders 2,4,6 and fire on 1,5. #3 was dead also. After looking at the site Trent sent me to and following some of the steps listed I tried the following. I swapped the red and red/white wires going to the packs along with the blue and blue/white wires. The problem moved with #2,4 firing, 6 was dead and no fire on #1,3,5. Then I swapped the coil wire for #6,4.#4 died , #6 fired. I then swapped trigger wire #2,6 #6 fired , #2 dead. After replacing all wires I ohmed trigger wires out .Here are the results, <br /><br /> yellow sleeve black sleeve<br /> brown-----------------purple 1286<br /> white-----------------white 3.26meg<br /> purple----------------brown 1271<br /><br />Here are the readings for the bias to ground.<br /> left bank 14.86k<br /> right bank 15.14k<br />from what I have checked it looks like I need a trigger and stator. If any of you experts have any other info or diagnosis please feel free to let me know especially if I'm headed in the wrong direction.Also what are the chances of both of these devices going out at once and what could cause this?<br /><br /> Jimmy
