vegaschef364
- Joined
- Jun 24, 2022
- 24
I have been around boats most of my life, but last year bought my first one so if my lingo is off a bit or don't have all the info I apologize. Bought a 87 Cobalt open bow w/a 205 V6 Mercruiser Alpha One Thunderbolt ignition w/power steering, 4.3L I think. It was in beautiful shape, the owner took very good care of it, less than 600 hrs on it. Used it for 3 weeks last year, in Missouri Lake of the Ozarks. Then garaged it, winterized it, pulled the chocks? opened up 2 large hoses to drain the water and put the battery on a tender. Gas tank half full and 95% positive I put in stabilizer. Got to the lake earlier this week, closed everything back up and put it in the water. Ran around for 20 min or so alone, then hooked up the tube for the kids. Ran fine for about 1/4 tank then it started briefly losing power, maybe from full power to 3/4 maybe 1/2 power, enough of a loss that I had to grab something to stop from falling forward. And it went back and forth for a little bit. dropped the kids off and filled it up, seemed to be fine but started happening again. First step was replace fuel filter, still had the original charcoal filter in it, so replaced it with the quicksilver paper type. Ran fine for a while on its own, hooked up the tube and started happening again. Does not seem to be missing, no odd noises when it happens, only the loss of power, and seems to only happen when I am pulling the tube, and past half throttle. The lines all look to be in great shape, replaced within the last couple years. I am no master mechanic but am pretty good with cars, can fix most things myself as long as no special equipment or hoist is needed. But new to the boat owners world so could use any advice on this issue, as well as any advice for a new boat owner. And thank you in advance for any helpful words given.
