87 mercrusier 3.0 litre alpha 1 trim/tilt
stug
whichever position the outboard is in, my gauge is pegged out all the way to the right at all times. . Where should I check first to start solving this problem.
I loosened 2 screws and was able to rotate the sensor on the port side.
on the starboard side one of the screws is not moving out too well i soaked it with rust breaker tonight.
should I look for voltage somewhere? or rotate the sensor while someone watchs gauge?
Btw, i got her back on the river monday after changing the impeller. Engine runs great and oil level remains stationary after running. gonna start oil and filter changes after every weekend to try to get more moisture outta crankcase.
