Deepblue22
- Joined
- Mar 31, 2007
- 51
Attempting to get this one ready and all sorts of issues but a good one to learn on. Compression is low in top cyl but with oil the comp jumps up so I think this might be stuck rings. Today I tried to run some fuel additive to see what would happen, if it could clear out potential carbon and unstick the rings. But instead the motor overheated after about 7mins at idle. The block was hot to touch esp near top cyl and the water stream was hot. The water pump is rebuilt and the water stream was not 100% of its power but I thought an ok amount of water for idle speed on a garden hose application. I removed the thermostat cover and pried out the thermostat. The thermostat was closed, and it was dry on both sides. No evidence of water in behind thermostat. Evidence of water around the poppet. I boiled the thermostat on the stove and it did open up properly. I dont have a clear understanding on the water flow path through the block but I assume there should be water present either in front of or behind the thermostat? Can anyone confirm that. Would this mean there could be a plugged passageway? Any ideas how I should proceed from here? SN is a729226. Thanks!
