We just finish rebuilding a 2.3L OMC cobra motor, after finding the carb. screw on top of the 4th piston.
We started the motor up with the hose hooked up and the motor ran smooth everytime we started it up. No leaks seen.
So we took the boat out to a lake, after a few minutes in the water, the engine ran like crap and eventually wouldn't keep running. We check the oil, and its milky white. This is water mixing with oil right???
Now we used all new gaskets, and also replaced the flap in the exhaust. When the boat is not in the water, it runs fine, but as soon as we put it in water, we get water mixing with oil.
Has anyone ever experienced this?? Any ideas of what might be happening? Could a gasket be wrong?? Maybe i missed a plug or hole? Thanks.
Carlos
Carlos
