87' vro 150 tough to get on plane
ranger374
engine idles fine, but sometimes when try to get on plane it will shutter and not go past 2000 rpms. back off throttle and try again and it may pop up great or still shutter. changed water filter and plugs, new gas and no clue what to do now?
jonesg
Re: 87' vro 150 tough to get on plane
MAybe its time to rebuild the carbs.
emdsapmgr
When it is not running properly, use an inductive timing light to check the spark pulses on each of the 6 plug wires. See if you have good fire on all of them.
kenmyfam
Compression and spark check, also check to see if the plugs are all in the same condition.
Let us all know your findings.
ranger374
had my buddy do compression check its fine checked plugs all good. still no clue clue what it is. the weird thing is that its not all the time.
