87yr 48 spl
moose211
i just got the motor cheap it got spark and im trying to pull start it because i do not have the harness its hard to pull but any wy on the comp. test im getting about 130psi on each cyl is that good :eek:
FlyBoyMark
Ensign
Re: 87yr 48 spl
Sounds like you need some wires and batt. juice and its gonna scream.....squirt some tcw-3 oil in the plug ports before ya run it and make sure the carb(s) are varnish free, water muffs or in the water. Might replace the water pump if its been sittn' a year or more. DONT run it without water!!!!
