88 125 force idles but wont go
fig
was out today boat ran fine stopped when i tryed to go it started to take off then bogged down like it wasnt getting any gas charged fuel filter and ckecked the one on motor still same problem
roscoe
Re: 88 125 force idles but wont go
If engine seemed like it was flooded, change out the fuel pump diaphram.
fig
one thing i left out the fuel bulb isnt staying hard all the time
pnwboat
Bulb should get hard when you initially pump it up by hand. If you check it again after you've been running for a while, it may not be hard but should get hard again after pumping by hand.
ROSCOE's suggestion about the fuel pump diaphragm is what I would do. Easy cheap fix.
john from md
Make sure that your vent is open on the tank, Next, how old is your ball and fuel line? If it has been on there a while, the check valves in the ball may be going bad.
Let us know what you find.
John
fig
John
changed ball and diaphram still doing the same thing was told it could be my stator
john from md
While your trigger timing may be at fault, the stator wont cause your symptoms.
Do a carb/timing sync by the book and then take it for a run. The problem may be that your timing is not increasing when your trottle valves are opening.
Regards,
John
