Re: 88 150 evinrude sticking in gear
DJ, I finally got a chance to take a look at this. The cable seems to work fine. It definately moves the linkage on the side of the engine. I had to do it myself so, I was watching it from the binnacle ( about 5 feet away ) After playing with it I started the engine on the flush and guess what...it was in reverse. I pushed the binnacle forward,way past the shift point and it clunked out of gear. The motor was running at the time at relatively low rpms because I moved the binnacle so fast the engine didn't have a chance to rev. The only thing I noticed that was not quite right was the point where the shift cable housing attaches to the side of the motor there is a keeper with a machine screw holding a knurled wheel that looks like it 's for adjusting the cable. the cable housing was loose under this keeper. It wasn't loose enough for the housing to pop out but I could jiggle it. I drained the lower unit and didn't find a milkshake or metal bits although the oil was VERY black. what's next?
Again, thanks for your help.
