Hello gentlemen...... and ladies,
So, I bought a bayliner capri over the winter. It was winterized, so I didnt want to mess with it a lot. I put it in my heated garage and left it there till a couple weeks ago. Once it started getting warmer I filled up a large barrel with water and fired it up. Ran decent, but a littlle rough.
I figured a lot of the roughness was just because the gas was from 6 months erlier. So, yesterday I filled her up and took her out for a run on the lake.
Everything was working fine. So, we threw a rope on the back and blew up the tube. While pulling the kids around it struggled to get up to speed. Not a big deal I figured since it was pulling a big tube, so some force was expected.
It quickly went from full throttle to dead in a second. I put it back in neutral, and fired it back up. it took a little coaxing, but did start. We went another 20 feet and it started to peter off, so I started playing with the throttle position a bit to figure out if it was running lean, too rich, no gas, too much gas...... Then it started a fient knock. Then it got louder and louder. The engine then died.
Got a tow back to the beach, put it on the trailer and back home. Get home, back in the bucket of water and I can get it to start, but idle is a LOT rougher than it was before.
I pulled one of the plug leads off while running to see if I had a dead cyl. Fisrt one off, no change in rpm or sound. Ok, next one off, same thing!!! Figureing something really is not right I pull a 3rd one off and the engine stalls. Put them all back on, start back up, then pull the last one and it stalls again.
So, cyl 3 and 4 are working.
Grab my compression tester, run it on, and I get ZERO on number 2, and maybe 15 or 20 psi on number one. It was still a LOT lower than I would expect.
I know that I could try dumping oil in and see if compression gets better....... But, I always thought that was the test for LOW compression, not NO compression. So, even if I did that, I dont expect to see anything else come out of it at all.
Now, my theory is...... I have blown the head gasket between the 2 cyl. So compression from one spills over to the other, rather than showing up on my gauge. Which is why they are not running right. I am hoping if I tear it down that I will find the split I think is in the head gasket.
If its not that, then it would have to be a stuck valve, which I would also find on the way to the head gasket anyway.
Its VERY inlikely that I lost all 3 rings on the piston. And if one is broken, I would still make compression, and or have a seized engine after it wedged itself into the cylinder wall.
So, what I am looking for is confirmation that I am on the right track. If you have read this far, you now know everything I do about this situation. I am planning to tear it down monday morning and start looking around.
Now, I have a few questions.
1) Would a gasket kit for a ford 2.3 from a mustang be suficient to repair this? or is there some sort of a difference in the material or design? I use this boat in fresh water, and it has fresh water recirc for cooling
2) If I get to the head, and find the valves good, and the gasket good and a broken piston ring, what are my engine swap options? if anything I would LOVE to grab a merc 3.0 and throw that in. But have no desire at all to change out the leg. But cant find ANY info on if they are compatible at all with a merc engine and OMC leg
3) Am I even on the right track with the head gasket, and is there ANY way at all to figure out if that is it for sure besides pulling off the head and looking?
Any and all advise, opinions and ideas is more than welcome!
Look forward to your replies
