88 2.3L omc overheating please help..
j4gwig
Ok I have a new problem,there never ending sometimes,,ok here's the deal,I just changed the impeller and housing being it had a crack in it,had it out a couple times seemed to do fine,took it out today and run fine at low idle out of the harbor, when i got out on the lake and nailed it she got hot fast,,pulled it out of the water pulled the impeller out,seemed to be fine,put it back in the water run good and cool at the dock,even run rpm's up to 4 everything seemed fine,took it out and nailed it,got hot before i could hit top speed,,what is going on,its getting hot under a load,now the housing that holds the impeller in not perfectly round,is that normal one side is kind of oblong ,sure could use some insight
