scagwildcat
- Joined
- Aug 1, 2010
- 6
hi all, i just bought a 88 four winns 180, my wifes boss ,had it since new and had not used it in a few years due to the kids not being around now, i was told that all gauges worked, he maintained the boat and is someone trustworthy, i serviced the boat, and have been using it every weekend.
my problem is, that i have found alot of things that need to be fixed here and there, no big deal, however, i cant get the trim gauge to work, and when i trim down, it makes a loud noise, like a belt woud make, going up works smooth, it does this with the motor on or off and at times if i go from up to down at the dock, it works fine with no noise at all? i dont get it, ive checked the fluid and it seems fine, is there any grease points? as far as the trim guage, how do i know if it is the wires or a bad gauge? also, i noticed a round disk like thing in the bilge area under the motor just sitting on the bottom not attached to anything? the wire that is comming out of it is not the same color as the trim wires that i have checked out... im sorry for the book i wrote, i appreciate any comments, thank you guys...
