Hello,
When I had to disconnect the main engine harness plug to pull the engine, one of the pins came apart and stayed with the opposing plug end. After i did what i needed to do and hooked the harness plug back up and started the engine it turns out it was the temp guage(of course). My question is does anyone have a wiring diagram of the pin location in the plug showing the color code? Since i cant rebuild the plug i was just going to split the wires and put a jumper around the harness plug.
Thanks
Cole
Thanks
Cole
