Re: '88 7.4/Alpha 5500 lbs. Apollo 15.5 x 17
The more a prop wears, the higher the RPM will be...considering we have some bottom fouling, it may even out. If we go to a 17P, I would recomend a test prop first because by my calculations, a good 15P in SS is going to be the best bet. The 17 may put you in the lower part of the RPM range, so a test prop would be best if you can get one to test...possibly a Mirage plus.
