88' 70hp Johnson Air Silencer
pb&jellyfish
I have a 88' 70hp Johnson on a 15' Glastron. The motor runs great except for out of the hole. When I throw the throttle down, the motor hesitates before getting power. I tried pulling a skier and it would bog down completely and never get power. I have cleaned the carbs and everything looks good, but I still have the same issue. I do not have the air silencer attached because I need to buy the proper bolts. My question is about the air silencer; will the air silencer not being installed cause the motor not to run properly? I know certain carbs need a restriction from a filter or something to perform right. Thanks for any feedback.
Daviet
Re: 88' 70hp Johnson Air Silencer
You can run it without the air silencer, you might notice some intake noise. Have you checked compression,spark and spark plug condition and fuel system?
pb&jellyfish
Yes, I have checked everything, and I can find no other source for a problem. I fitted the air silencer back on without the gasket and all the bolts, but I only had a chance to do a quick run with it; i did notice a difference though. Once I properly install everything I will give an update.
