dynatrak94
- Joined
- Apr 18, 2010
- 9
first off i did my fair share of searching and i couldnt find anything that was persistent like my situation was, so just preapologizing if it seems like another story. i have an 88 evinrude 120 looper motor and took it to the lake over the past few weekends, idles fine and boat will shoot out of the hole no problem run about 100 yards and the motor will drop from 5500 to 3200-3800 will rev back and forth between the two for a minute and eventually bog down like it is running on two cylinders. i can cut it off or let it sit for a minute and it will plane out but the problem persists again. i check compression, everything seems ok, and fuel is fresh with new filter. i pulled the plugs and they look wet as if they were not firing. also i disconnected the temp switches thinking it might have to do with a cooling problem but it still does the same thing. it appears the powerpack has been replaced but no way of knowing for sure. i have done a fair share of research and everyone refers to powerpacks and coils breaking down once they warm up or get hot. just want to know if anyone might have had the same problem, any info would be much appreciated and useful, thanks.
