88 Force 125 Engine Input For a Newbie
DDG53
Well i'm going to my best and describe my issue. Me and my brother-in-law just replaced the impeller. Stars up real smooth.. But after a couple die downs about (7 times)....Then it just ran straight. Mind You guys this was with a test tank and not a float. So this is my break down..
1. There is about 5 gallons of gas with an eye ball of 2 stroke fluid when i mean eye ball pretty much from the reading the back of the bottle..:confused:
2. No Sea Foam...
3. Just changed the plugs..
4. Lots of smoke coming out of the exhuast...:(
5. Charged battery..
So I'm figuring that most of you would say tune-up..witch mostly come down to it. Just maybe some input before the shop and save some money.. Thanks Guys..
jerryjerry05
Re: 88 Force 125 Engine Input For a Newbie
So just what is it doing?I'm confused.Sounds like it was stalling then it straightened itself out.
A tune up is basically new plugs.And a timing check and setting the carbs.
Get a manual to check timing.Carbs,turn air screw in till it bottoms and then out 1 and1/16th turn.Remember where your were set at and see how much difference there is.J
DDG53
OK ill do that this weekend but timing check is that the same as for a car? :confused:
jerryjerry05
No get a manual.Some say Clymer is better than Seloc.I like the factory ones.
J
