I replaced the impeller on my 88 Force 125 and now it is only operating in first gear. When I start it (controller in neutral) it runs as if it is in first gear. I took it out on the lake and it is as if it stuck in forward. If I put it in reverse and give it some gas it goes forward.<br /><br />I made sure that the shift rod was hooked up correctly and is moving appropriately when the controller is moved. It seems that the lower portion of the rod has become disconnected/broken off from the gears it is supposed to be shifting.<br /><br />Anyone have any other thoughts before I tear open the lower unit? Will I have to tear it totally apart to fix this problem? Thanks.
