88 force 125 tilt and trim wiring diagram
stoudt21
i just bought a 1988 force 125 with power tilt and trim. my boat has ever had power tilt and trim before and all that came for wires on the tilt motor was 2 wires about 12" long. how do i hook them up to the throttle controls or do i have to buy a seperate control for it, also how do i hook it up to the engine or do i hook it up somewhere else. i have a 17' bass bayliner.
Re: 88 force 125 tilt and trim wiring diagram
hi , if you have a throttle control with tilt and trim option you can wire t&t from there , if you do not have a throttle control with t&t option you can buy a t&t switch (if u dont have one) and install on your dash panel . open the engine hood and look on the front left side of outboard motor (looking from the back of boat) you should have 2 relays and 1 circuit breaker if u dont you will need to buy them. i can send you pics of my t&t installation system.
post me your email address so i can send them straight to your e-address . my e-address is traileroman32@aol.com
stoudt21
ok my email is flynavy21@aim.com that would be great thank you very much!!
