88 force 50hp impellar related/seal question
cbercaw
Everytime I replace my impellar, the rubber drive shaft seal that goes on top of the brass water pump collar is broken and shredded. It is cylinder shaped and has a tapered/mushroomed top. (not talking about the driveshasft seal under the impellar wear plate.) (The brass collar is worn too on the outside) Does this indicate another problem? The diagrams are unclear and the manual doesn't mention it. What is the correct installation of this rubber seal and what does it do.? It doesn't seam to seal anything too well and it looks to me like it doesn't do much. I know i am wrong about that but I hope I don't have a more serious problem.
Shife
Re: 88 force 50hp impellar related/seal question
On my '87 B series 50 the seal and retainer you depict go at the power head end of the shaft, not under the water pump housing.
cbercaw
This is the seal in question, If it goes at the top of the drive shaft..what holds it and the retainer in place? The retainer is recessed on one side and seems to fit perfectly on top of the water pump drive shaft seal. The rubber collar always tears and I don't understand where or how it goes and does anything..
jerryjerry05
Thats not a w/p seal that piece goes over the splines at the top of the shaft.It supposed to have a small metal ring that it sets in.It's to keep the splines greazy.J
Shife
I still have my engine apart right now so I'll take a pic or two when I get home tomorrow. Hopefully it will help you.
cbercaw
that would be appreciated. Thanks
tmryan
Since you have your lower unit off. Is the a gasket between the water pump housing and the brass water tube that goes to the block??
cbercaw
no, there is not a gasket, just the plastic tube from the pump housing.
tmryan
thanks for the info on the water tube Tom
Shife
Sorry it's taking so long, but I'll post that pic tomorrow. Been super busy.
Shife
Seal is at the top of shaft.
cbercaw
Nice photos, Thanks for the help, Very helpful!
