88 force 85hp prop 13x19 15 spline
Hello I'm looking for info I've got a damaged prop that is no thru exhaust prop can i put a thru exhaust prop on a 88 85hp force outboard 13x19 , 15 spline ?
jimmbo
Even if it were to fit, Why? It would just be creating drag
SkiDad
Yes you can. I ran both types on my boat. The thrust washers are a little different taper though. You might consider a 17p unless your boat is really light.
