DunbarLtd
- Joined
- Nov 8, 2016
- 357
I've been wondering if the slow moving tilt is because of air in the system or just low oil. I added new oil after repairing the valve body maybe 3 years ago and havent touched it since. Its worked ok but to me it seems slow. Not sure how I could test the pump motor to rule that out.
If I wanted to completely drain and refill what is the recommended procedure and also this system calls for 30W non detergent motor oil which is what I used but I have read that ISO32 hydraulic oil is better?
So how to drain and refill and what oil should I be using? Thanks...
