temple1975
- Joined
- May 5, 2009
- 59
I am in the process of replacing the cylinder head. I was hoping you guys could help with a few questions.
#1 what if anything can be done about the hairline crack I found (see photo)
#2 can and should I use emory cloth to clean the block mating surface where the gasket goes
#3 do you use any kind of sealer when installing the head gasket
#4 should I do anything about the carbon on top of the pistons while I am in there
#5 what can be done to make getting the bolts out eaiser in the future
Thanks in advance
Brian
Thanks in advance
Brian
