HI guys and gals..<br />the re-build I did my 50 horse 1988 was a nice clean job, ended up with rough idle, found bad plug wire.. changed the charge coil which was suppose to deliver 150 volts, ended up getting 70 to 80 volts at idle and start speed.. so now I have a new charge coil, new plug wires, new plugs. still rough idle and some misfire.. can't help but think that the flywheel magnets are weak just from the 70 volt readings... has anyone experienced a bad flywheel? I put a screw driver to the magnets and it sticks well.. ordered a new trigger coil but think that was a waste of money.. is there any way to re-magnetize the magnets there?<br />looking forward to feedback.<br />thanks.
