88 maxum restore
i posted on here a few weeks ago with To be or not to be, after deciding it would be, I started investigating further on the flooring, I cut out a few small pieces that were bad, the foam underneath is damp, real damp. So is that a bad thing or will it dry out? Another thing, how in the world do you get the seat boxes up? Thats worse than pulling teeth. Let me know what you think guys, this is a make or break situation for me.
chargerboy
Re: 88 maxum restore
If the foam is soaked, you should replace it. It probably won't dry out. Are your seat boxes fiberglass? If so you might need to cut them out with a grinder.
