Hello all. New forum member. Just picked up an 88 Wahoo 16 dual console from a friend. Had the motor running yesterday and sounds like it runs great. I checked for charging voltage while running and only got 11.6. Tried revving the motor a bit, no change.
Waiting for manuals from previous owner to start digging into to see whether it could be a stator issue or rectifier. The motor serial number is b372970.
My question is, are these motors prone to stator failure? When googling the issue, on another forum someone said the stators are a weak point in these motors? But I only saw that said once. Is that true? Hoping for the rectifier to be the issue as a rectifier is quite a bit cheaper, but whatever it is, it is.
My other question is, I see in the parts diagram, there’s a pickup coil under the stator. I assume the stator is just for charging and the pickup coil is for spark, and tach?
Thanks all for any advice.
