My 88 special wouldn't start at the ramp the other day.It would spit a few times then die.Used the same starting procedure as usual.Finally popped the cover and noticed fuel spraying around from the red lever and out the end of the choke solenoid.Looks like time for a solenoid rebuild...question is,is there a rebuild kit available ,and if not,which parts(from BRP website) are usually the culprit for those symptoms?
