Re: 88 spl high speed miss
You've got two separate issues going on. The tach issue is probably a bad rectifier-part of the charging system. When the rectifier goes bad, it quits charging the battery. Usually simlataneously, the tach starts to read erratically. If you purchased a Bombardier rectifier new from a dealer, it has a 1 year parts warranty. Make sure the two engine cables are really tight on the battery terminals. The miss is on the ignition side of the electrical system. That engine never came with mallory wires. Factory wires are a solid core wound steel wire. Sold in bulk at any Bombardier dealer. It is possible that the wires are shorting to ground when the rpm's increase. Check the positioning of the two bottom coil wires. If they are too close to the two cowl latches, the wires can spark to ground. Make sure you are running Champion plugs: QL77JC4.
