Recently the engine has received many new ignition components including a trigger (you will see why I mentioned this later). I also did a carb cleaning and reassembly with new gaskets. This was all done because all of a sudden I couldn' get up to plane, engine bogged down and I also lost spark to 3 cylinders and could only get 12kts max. I ran it for ~3 hours at this speed for I had 13 nautical mile trip home.<br /><br />After performing the above tasks, the engine now has a "bad" spot in between no wake speeds and WOT. 2000-3000 RPMS seems to be the problem zone. The engine sounds different and shakes a bit more. These are speeds I'm hardly ever at. But, I don't know why this is happening. Also, after I've been up to plane this problem doesn't occur, unless I've been trolling for awhile, same thing happens.<br /><br />Idles superiorly and races like the best of them.<br /><br />Just hoping it isn't something major. Could the timing be off? Could the engine have been running lean on that long journey home? Should I stop obsessing about every little detail? (Sorry, never can happen.Just my nature)<br /><br />-Thanks <br />andy
