boredindaboro
- Joined
- Sep 25, 2014
- 34
I have an 1994 88spl. The issue is I'm about 1200 rpm off of proper wot. When I move the control to max throttle it coughs. I believe it is running rich but I can't just change the jets because the carbs have been swapped, and I believe the venturis are different sizes. How would I compensate for this? I'm almost positive it's a rich issue and I believe leaning it out slightly will get me the extra power/rpms it is supposed to have. I don't remember what size the original carbs venturi was but I remember commenting the replacements were larger. I know there was a difference in the main jet size but I'm not sure where or what size I need to correct this issue. I'm open to other suggestions but I've already repropped and it made no difference in rpm. The symptoms are hard hot restart, low rpm at wot, rich blue smoke, dark dark plugs. Thanks everyone for your help.
